Fridge: Sears 970-681020
Combination relay: 213615005 (embraco/eecon tsd-115/127v-60hz-y)
Compressor: egz 70hlp embraco
Symptoms: Click, BRRRRR (4 seconds), Click....... no cooling
Tests: Pulled the combo relay. Tested continuity on the motor, all good. No rattle in the relay, mild smoke smell. I pulled the overload out of the relay and found a slightly burned connection: https://imgur.com/a/DnUPIAC
The relay left to right (start-run?) reads 31Ω and the thermistor appears intact
Question: I found a single combination relay of this exact model # but it costs $195 .... can i replace just the overload protection part, if so, what part #? This looks visually identical. If I have to replace the whole relay, what are the chances this actually fixes the problem, i don't want to spend $200 on a part that dies in a few weeks. And are there alternative relay parts other than specifically the #213615005?
I'm able to test other stuff if needed.
(I erred on the side of too much information in case it helps any, I know people are busy after the holidays)
Edit: I'll probably buy and install this tomorrow unless an expert tells me otherwise.
