I'm gathering from research that generally smart fan control switches are single pole only. We have wiring for a 3-way switched fan/light fixture.
  1. Do 3-way smart fan switches exist?
  2. Do intrinsically smart fan/light fixtures with 3-way switches included exist?
If neither 1 nor 2 are true, do we have other options besides just converting the wiring to 1 way?
cbmanica
  • 331
Never say never, but: FWIW, I have never seen a 3-way smart fan switch or smart fan with 3-way switches. Yes, you have another option: use a smart fan controller like "Universal Smart Wi-Fi 4-Speed Ceiling Fan Remote Works with Google Assistant, SmartThings, and Alexa" (not an endorsement). Use any of the many devices compatible with those home tech systems to control the fan from anywhere.
MadMonty
  • 2,341
You say "3-way" but what you actually want is control of the fan/light in two places. You're not married to the idea of using dumb, plain "3-way" switches in the second location.
Generally with smart switches, when you're dealing with anything more than a plain on/off switch, the primary location is handled by a smart-switch master, and then secondary locations are handled by a smart switch remote. They don't reuse the legacy on/off switches, because they have more to do than just on/off, and they want to provide the full suite of controls at each location.
Some will provide some degree of support for it, but obviously the remote being a simple on/off switch will not give access to all abilities.
Generally the master switch needs to be as close as possible to the lamp/fan, so if the 3-way arrangement is power -> switch 1 -> switch 2 -> fan, the master goes in the switch 2 location, and you don't get a choice to that.
