I recently replaced my chandelier with a new fixture (and new bulbs) and noticed that when my dimmer is off the light is still on. Dim but on. I measured 10V between Load and ground.
If I remove the load from the dimmer I no longer get 10V between the load wire and the ground, maybe just 1 volt (which probably rounds to zero or is induced?). If I use a dumb switch [replace load and line on dimmer to the dumb switch] I also get 0-1 volts.
Is my dimmer switch bad?
Stuff I've also tried:
• Continuity tested all the wires to ensure the line/load/neutral and grounds were in the right places (they were)
• Wired a new chandelier ($3 at HD) and one of the A19 bulbs from the old chandelier to the switch. When the new chandelier and single A19 are both connected the new chandelier appears to be completely off! There's still 10V on the circuit but everything looks off. When the new chandelier is removed leaving just the $3 one, that bulb also looks totally off (and it's a dimmable bulb too). But when the $3 fixture is removed the new chandelier turns back on to being dim.
Thanks so much!
Edits to distinguish from duplicates:
First of all - thanks for pointing me to this question which suggested adding a resistor into the circuit. My question is not the same as the linked duplicates because:
  1. I'm already using a WiFi switch which uses a neutral. In many users' cases a WiFi switch fixed the issue because it used a Neutral, my switch uses a neutral but I still have lights which glow when off.
  2. Additionally, the dimmer already designed to be used with LEDs but I still have this issue.
TLDR: I'm asking if a WiFi dimmer with a neutral should ever have any volts going over the LOAD when off. Does that make the switch defective?
wizlog
0 Answers0
