When I installed the new pressure switch about a year ago it was set a bit low with the pump turning on at 25 psi and off at 50 psi (I was aiming for 30/60). I just went out there and the pressure gauge was at 80 psi!
I turned the top pressure sensitivity on the gauge shut off at 65 psi, but when I cycle the pump the water pressure drops slowly (as expected) to about 60 psi, then I hear a rush of water and the pressure suddenly dramatically drops to about 40 psi and the pump kicks back on and pressure is restored.
These systems aren't that complicated but I'm at a loss as to what would cause that sudden drop of pressure. Is there a backflow valve that I'm unaware of that may have been damaged or something?
