I have two three-way switches controlling two lights in my laundry room at either entrance. I want to remove one altogether and replace the other with a Kasa motion sensing dimmer switch which is single pole and requires a neutral.
On existing switch 1:
- incoming 14/2 black and white. When testing the wires, white is energized, black is not
- outgoing 14/3 red,black and white White incoming and outgoing are connected
- black from 14/2 is connected to common
- Red and black from 14/3 are travellers
On existing Switch 2
- incoming 14/3 Red and black are travellers, white to common
I have tried every possible combination of things i can think of without success. I want to eliminate switch 2 altogether and just use switch 1 as a single pole. I cannot determine if the power is incoming to switch 1 from the lights or if switch 1 is where the power comes in. Since the white is energized on the incoming 14/2, I’m thinking it is but there is no access to that in the ceiling…
Help!
