This is a follow-up to my other question. My house has a wood frame and vinyl siding.
Installer came out to do a range hood install and for the outdoor vent cap he just sealed it with silicone to the siding. Allegedly he sealed the duct opening to the sheathing as well, but I have no way of knowing unless I take it down.
I'm worried about the weatherproofing of the job, so I've frantically been doing research on how to fix it. I think I have figured out how best to do it:
  1. Cut a square hole in the siding
  2. Remove a few pieces of siding in the work area
  3. Cut diagonally to create a flap in the house wrap on the top side of the vent hole
  4. Silicone the top and sides (not bottom) of the vent cap and screw it into the wall
  5. Seal the sides, then the top of the vent to the wall with flashing tape - top strip goes directly on the wood under the flap of house wrap
  6. Reattach the house wrap over the top of the vent and reseal with house wrap tape
  7. Surround the vent with J channel, tape the flange of the top J channel piece with house wrap tape
  8. Reattach siding
  9. From the other side of the wall, fill the gap between the duct and the exterior wall with firestop foam
Here is a crude graphical depiction of what I'm thinking of.
TLDR: Flash it like a window, use J channel trim, foam to seal the air gap
Does this sound reasonable? Is there any gotchas I've overlooked?
Additionally, I'm a little confused about how to approach the "not sealing the bottom" guideline regarding the gap in the exterior wall. Should I not be sealing it all around somehow?
My references:
0 Answers0
