You can see that most of the conductors have their grounds crimped together in the deep part of the box.
A box extension was added to this at some point, so it is rather deep, but then I noticed that one of the conductors has a second ground clip to the box extension, and that is how the ground connection to the rest of the grounds is currently being made. To be clear, the singled-out ground wire is a load, not the line conductor here.
Is this an acceptable technique when I replace that one conductor so I can do the same thing the last guy apparently did -- ie. avoid cutting those other grounds by clipping to the box?
I need to replace the conductor with the separated ground wire on the right side of the photo because it is 14 gauge on a 20-amp circuit and needs to be replaced with a 12 gauge because I am redoing the wiring downstream. The other wires are all 12 gauge. If I don't have to cut those grounds apart that are all crimped that would be best because the other conductors don't have enough service slack to pull them in further after cutting the grounds which would greatly expand the scope of work here.
