I am looking for an explanation why yellow gas appliance connectors are single-use. What is it that makes them not reusable? Does it wear and reshape sympathetically so that it can't form another joint without gaps and leaks?
Asked
Active
Viewed 263 times
The most likely answer that's not just "liability insurance CYA" [which is certainly a possible answer] would be the use of a metal-to-metal seal where one part is a fully annealed but work-hardenable metal, such as a copper alloy.
That would be soft and easily deformed to make the seal the first time it was used, and the deformation would work-harden it so it would not be as soft and easily deformed the next time, so it might not seal properly.
Such seals are common in ultra-high vacuum work. I do not know if gas connectors (now) use such seals in some manner, as all direct knowledge I have of fuel gas for homes is decades out of date, and was mostly propane anyway.
- 11
- 293
- 637
