I've moved into an old stone house in the UK. The water system consists of:
- Some type of well under the conservatory. It looks very deep and has a good flow rate according to the survey.
- A submersible pump inside the well that pumps water up the hill behind the house to:
- A very large water storage tank. Then the water goes back down the hill into the house, where it also goes up to:
- A small water storage tank in the loft space below the roof. This feeds into a:
- Hot water boiler on the first (2nd in US) floor right below the loft tank.
I keep getting various advice on what all the various components are doing and which are necessary. My questions are:
- Why is the storage tank on the hill necessary? The well has enough water throughout the year. If it's to increase pressure, then:
- Can this type of pressure be replicated by an inline (or some other kind) of pump that increases the pressure? What are the pros and cons of doing this instead of, or on top of, having the storage tank?
- Why is there another tank inside the loft? Is this to increase supply to the hot water boiler? Why can't this be accomplished with the storage tank on the hill?
Someone gave me advice that each component was put there for a reason, but it would be nice to know if anything can be simplified without sacrificing resilience or efficiency. Is an inline pump plus expansion vessel recommended? Thank you!
