I just removed a double wall oven, because the control panel had partially melted. (I suspect the previous owner used the self-clean function, which in my opinion is an anti-feature for ovens.)
Rather than replace it with another double oven, I'm considering a single wall oven and a separate microwave. (As opposed to a combo; separate seems smarter to me, since if one breaks I only have to replace the one the broke.) But in order to accomplish that in a cost-effective way, I'm going to need a source of 120v, and (I suspect) on a circuit with at least 15 amps to spare.
In the attached photo, you can see the steel conduit for the original oven's 4-wire 240v supply. (Emerging from the conduit, it forks into 2 branches, one for each original oven. That's just how the old double-oven needed it.) I'm wondering if I can use just one of the legs of one of those forks, to supply my 120v microwave. Is that allowed by code? If not, what's the concern? (This is my preferred solution, if permissible. The oven was the only thing supplied by this breaker, which IIRC is rated for 50 amps.) This could be a hard-wiring or I could add in a recepticle, whatever is needed.
