I have a Filtrete 3M WiFi thermostat. As expected, it takes a C wire, which my apartment doesn't have and the apartment maintenance folks wont' let met wire either.
However, there's a wall socket right next to the thermostat mounting on the wall.
Can someone walk me through what I will need to potentially be able to use the wall socket to power my WiFI module?
The thermostat itself works fine, it is just the WiFi module that doesn't work without the C cable.
gregmac
  • 29,300
  • 89
  • 162
You can connect an external power adaptor that provides from 12 to 24 VAC to the C and RH termainals of your thermostat. This forum has quite a few questions and answers related to that particular thermostat.
TomG
  • 3,998
