Airflow! I have been conducting my own experiments, and having enjoyed a huge finished basement in my childhood home, I eventually identified why our big basement, after 30 years, was always flooded and dank. It's groundwater and stormwater flooding downhill during and after downpours (though even a slight decline would also flood foundations and basements). Assuming your basement and house are situated even slightly downhill on your property that faces a paved (impervious) road, one solution would be to dig a trench parallel but angled toward the side of your house where it would continue downhill. The trench needs to be deep and wide enough (at least 18"-24" deep x 2 feet wide) to handle the countless volume of water and direct it toward a stream (even a dry creek bed). You'd install iron gate or heavy gauge flow-through covers on top so no one falls or trips over the trench. Another step (and it's costly, but recommended) is to have impervious heavy gauge plastic or special liner installed on the entire subterranean foundation. This requires digging alongside the foundation that would face the property incline and installing the heavy gauge moisture barrier on the brick or cinder block substructure. This prevents groundwater seepage that get through your foundation and into your basement. Even the slightest groundwater moisture will increase the humidity level in your basement and house. So, a moisture barrier is necessary to prevent water intrusion and also the damage caused by underground moisture. This damage includes destabilizing the foundation causing your house to shift and sink slightly on an end. This would explain cracks you may have noticed on your walls that are not underground. You would negate need of a dehumidifier. Still, if your basement remains dank, install fans. Circulating air is essential to addressing humidity, because moving air also dehumidifies the moisture in the air. Think of your hairdryer. Then, as I have found, determine which side of your house is getting the most sunlight, and which side is shadiest. Is your basement located on the west side? Or even the south side of your house. Reason is, humidity is the result of cold and warm air colliding. So, if your cool, temperate basement has a south or west facing exposed wall with no shade, and you have ventilation, cracks and unsealed windows, doors, or anything through which that warm air is flowing into your nice, cool basement, you will have humidity problems. And if any part of your basement has an open area, such as a crawlspace that runs the span of your house, you will have humidity. The remedy may be to enclose or create a barrier closing that opening to your crawlspace, or, install fans that would exhaust air from your basement into the crawlspace. This would help reduce humidity in your house while you dehumidify your basement using circulation instead of a heat-producing dehumidifier. Which brings me to my final point. Dehumidifiers produce hot/warm exhaust that is released into your cool basement. This creates humidity. (You see how complicated this is?) When you think about how a home's central HVAC works, you'll quickly realize just how many functions they have: Cool the air, circulate air creating airflow directed throughout the house with ventilation and ducts; dehumidify the air (which is accomplished by circulation, and compression and dehumidification which is the primary function of an AC system), and collecting/directing water from condensation in plumbing that is directed far from the house so it does not puddle and seep back in. So, you could have vents and properly sized ducts that enable sufficient force and flow of air into your HVAC. And short of all of this, I would strongly encourage your investing in a small, 9k BTU ductless minisplit, which happens to dehumidify better than any other type of air conditioning. You'll just have to direct the condensate away from your foundation. And whatever you do, use fans. Ceiling fans, box fans, and where applicable, exhaust fans (exhausting hot air out/cool air in). So far, I have been able to make my house quite comfortable strictly based on positioning of fans. I've had to deploy my portable air conditioner a few times, but I have been able to stave off investing in fixing my air conditioning systems. Hope this helps someone.
