My dishwasher uses a Bauknecht 2040W heating element:
Can you test if it's faulty using a continuity test?
If so, is the continuity test between:
  • ground and the positive,
  • ground and the negative, or
  • the positive and the negative?
Testing between positive and negative shows continuity but between either the positive or the negative and ground doesn't.
  • 20,909
  • 95
  • 135
Alex
  • 193
Continuity is "An unbroken electrical path in an electronic circuit or connector[1]". First thing, unplug the dishwasher or if hard-wired turn off the circuit breaker. Unplug the connector to the heating element and then test the contacts on the heating element.
A heating element is a semi-conductive (typically coil) that creates heat as it resists the flow of electricity through it, a.k.a. a resistor. Also, even though there may be a clear positive and negative fed into/through it, a resistor does not have positive and negative terminals so orientation of your testing leads doesn't matter. A conductivity test will provide some feedback, but a resistance test with provide more accurate feedback, set your multimeter to Ohms Ω and check that the value across the heating element is within manufacturer's standards.
Whenever testing a heating element, make sure you are actually testing the element and not a circuit before it that drives it!
[1] http://en.wikipedia.org/wiki/Continuity
Jason
  • 2,071
