We're (slowly) renovating the sash windows in our house and the current window is causing problems. What should have been a quick job (especially at this time of year!) has turned into a marathon because the putty won't dry.
We had to replace a couple of panes of glass (one was cracked and we broke another when using a heat gun to remove the paint) so we knew it would take a little while. On a previous window the putty took over three weeks to dry enough to paint partly because (as we thought) there was too much oil. So this time we rolled the putty on newspaper first to try to remove the excess oil. It seemed to work, but after two weeks the putty is still soft to the touch.
We've tried standing the windows next to a radiator but all that seemed to do was make it softer (which was obviously going to happen in hindsight).
So given that we don't want to reputty the windows what can we do to speed up the drying process.
We've had to seal off the room and cover the window as best we can in the meantime.
I've found this advice on DoItYourself.com which doesn't really help as it says use other materials!
The answers to this post on DIY-Forums are confusing at best and possibly contradictory as one recommends exposing the putty to moisture(!) to speed the drying process.
ChrisF
  • 16,973
  • 74
7 Answers7
Heat will make the putty softer, which is why you can heat it up to remove it. Putty pretty much stays soft for years. Initially, it doesn't really dry out so much as oxidize which forms a skin on it.
If you absolutely must paint it right away, you'll probably has to use one of the latex based glazing compounds. If you want to use a traditional one, paint it as soon as it forms enough of a skin that the paint will stick to it. Also, I think you probably should be using oil based paints, but check the instructions on the putty.
If you let use know specifically which putty you are using, that might help get better answers.
Zach
  • 1,555
Look Dap 33 is a linseed oil based product. The linseed oil has to dry down. Typically it takes three weeks. You will have to use an oil primer over the glazing, making sure the primer go over the putty onto the glass to form a seal.
Wipe down the putty with mineral spirits, this should remove some of the oils and help it cure faster.
I always use DAP glazing compound and have never had a problem being able to paint it 24 hours later. I think you may have a bad or old lot there. Go to the latex based products and you will not have the same problem again. good luck.
shirlock homes
  • 58,628
  • 87
  • 168
I've been a glazier for over 35 years and I've everything going with regards to putty. You can buy rapid setting putty where you mix in a powder that makes it skin in about 3 days or mix in a small amount poly-filler. The putty will be ready to paint within 4 days.
DMoore
  • 50,637
  • 93
  • 208
ive been doing stained glass for a number of years and i use a whitening powder that stained glass stores sell, you set your putty in place then grab a brush dab it in the powder and brush it over your putty lines works well dryies in a few days
drago
You could use a hair dryer and carefully dry the wet glazing.
Jerry_Contrary
  • 3,733
