In this question the OP mentioned that, when having problems with blocked toilet, as his first attempt he tried warm water method.
I would like to ask:
  • What is warm water method? For which purposes and in what situations can it be used?
Martin
  • 147
Using warm (should be very hot water) to break up plumbing blockages. Works for minor issues. You would simply dump hot water into the drain (or toilet) and let the heated water try to affect the material blocking the pipe.
DMoore
  • 50,637
  • 93
  • 208
