I have a switch in a metal box. 1 brown wire 1 red wire. It controls a receptacle in a metal box. The wires at the receptacle are 1 white 1 brown. Why? I want to change receptacle to a gfci and then add one receptacle after the gfci receptacle. There is no actual ground wire. Do I need one??? Also it is a single pole toggle switch and I want to change that to a rocker switch. 15 amp
Jamie
If the wires are in metal conduit(not cable), the conduit can act as ground.
Some switches and receptacles are self grounding though the mounting screws.
GFCI does not require a ground to work. Quite often they are used to add safety to old ungrounded circuits.
If the circuit is grounded, the test is to use a multi-meter between the hot/live wire and the metal box. It should read the local standard voltage. If not grounded then the meter should read 0 volts.
crip659
  • 32,986
  • 39
  • 85
