Can you run the hot water from the washing machine faucet through a regular garden hose ? And then use a y connector to control the temperature through the flow control valves ?
Asked
Active
Viewed 190 times
hot water in garden hoses is an interesting problem. sometimes it's good, sometimes not. appliance hose would work, but is much more expensive.
It would probably be best to install a shower mixer outdoors
Jasen
- 26,920
- 1
- 24
- 46
They sell Y-mixers specifically made for the washer hookups. For example:
The end of the Y connects directly to a garden hose.
Make sure to open both hot and cold water faucets at the same time, then control the temperature by partially closing the hot or cold.
Cheery
- 12,884
- 1
- 20
- 47
