I have a mystery 1¾" cast iron pipe (outside diameter) in my basement. It's ugly and rusting, and I want to remove it. I want to know what's in there before I start opening it up, but I'm out of ideas as to what it could be.
It has a black, rubbery (and oily in some places) coating along most of it. It comes in through the foundation in the basement below the outside grade, goes up to the basement ceiling, then runs along the wall for about 12 feet. Then it reduces into short 1¼" pipe that's capped off. The house is in Oregon as was built in 1930.
It's too big to be a water line or gas line (and the local gas co says there has never been gas at the house), and too small to be drain, waste, or vent.
I also don't believe it's an oil fill pipe. There used to be an oil tank in the opposite side of the basement. The old oil tank had a copper fuel line running to the old oil furnace. It has had oil since at least 1959, and was probably coal before that. I removed both the tank and furnace. There aren't any other (buried) tanks on the property either.
That leaves ... ? I don't know what. I'm certain it's not fuel oil related, which is probably the worst thing it could be (followed closely by a 1¾" water line under full city pressure). Is there a safe way to open up this unknown pipe so I can get rid of it?
Update: Thanks for all the responses.
I'm intrigued by the idea that it might be coal gas. The house is in NE Portland. I know there was coal gas in Portland, so maybe it's possible. The pipe enters on the street side of the house.
It's around 3 feet below grade on the outside, and I believe I have enough room to dig it up. That will at least tell me if it's capped off on the outside, or if the pipe goes off in some other direction, or connected to a big oil tank that was missed by the tank locator people. If nothing else, I'd rather try to open it outside - better to have coal gas, oil, or whatever leak out all over the front yard than in the basement.
I've also called 811, maybe the gas co or someone will be able to help identify it (though I think they don't find abandoned pipes, just active ones).
Update again: This was a gas pipe. I finally got the gas company to admit it after being told repeatedly and emphatically that it didn't exist and that there was never gas service at my house. (I told them that I was going to remove the pipe with a cutting torch...and engineer showed up at my house about hour later and helped me cut the pipe out).
It's for an old "low pressure" gas system, which is why the pipe is so big. It was in service at my house (with no gas meter) until about 1950, when it was suppling a kitchen stove. It may have also supplied a furnace (that was later switched to oil).
At some point about 25 years ago, the NW Natural re-lined all the old gas pipes in my area, and since my house didn't have service at the time, they disconnected it at the pipeline. But the previous homeowner just left 12 feet of pipe in the basement hanging down from the ceiling and blocking a window.
