I'm running outlets in my workshop. The wall has modular insulation blocks, which have a wiring channels already designed into them, so running cable through the wall is not difficult; I've already done so on the wall opposite the (surface mounted) subpanel and installed boxes for flush outlets.
But for the near wall, I am now thinking it would be easier, and more flexible, to run surface mounted conduit for the MWBC to supply 120V and/or 240V to the larger power tools.
However, I have already purchased NM-B (not NMC, as originally written) 12/3 cable for the circuits. Wasting that investment would not be a disaster, but copper isn't cheap these days.
Question:
Can I use that cable inside metal conduit, and if so could I have more than one in a single section of conduit?
If the answer to either is no, would it be completely insane to strip the outer cable sheathing and use its component individually insulated wires within the metal conduit? Again, could I run multiple MWBC's thru the same conduit?
Or do I need to/should I purchase single wires with a different kind of insulation (or at least certification) for this application?
