There's one major rule in electrical work this violates: movement.
Voltage is a measure of how much "electrical pressure" there is. A 1.5v battery is harmless to the touch because your body isn't a great conductor at lower voltages. But at higher voltages (which includes 120v) there's enough pressure that it will jump gaps. We call this arcing, and arcing is how you turn electricity into fire (i.e. spark plugs and combustion engines).
Backstabs are quick and easy, but they are notorious for losing the physical connection. Why? I'll borrow an image from this answer
Note what holds the backstab. This is a modern backstab, with what amounts to a brass claw. I've seen some old ones use nothing more than a glorified spring. This can provide a poor mechanical connection, especially if the device was moved a lot (i.e. an owner pulling them all out to take a picture for a DIY site...). Every movement of the wire can weaken the connection. So, as long as you never move the device, and you don't have a lot of big temperature fluctuations, you can be fine. But do you really want to trust a folded piece of metal in a device designed to be as cheap as possible to hold up?
You'll note the premium outlet next to it. It uses what I call a "side stab". The goal of "stabs" in general is to not go through the hassle of making a shepherd's hook and wrapping it around a screw (which has its own headaches). That system, despite being frustrating, will at least tell you when you failed because the wire pops out from underneath the screw. Side stabs are even better because you put the wire under a plate and then screw the plate down. No headaches with bending wire and making sure it stays in place.
