My plumber who installed my hot water heater 2 years ago is a ~@#%$@$%. He created a super weird construction above the water heater that does not satisfy manufacturer clearance requirements and prevents me from changing the filter.
It's really hard to describe and even put on a picture because it's such a tight space but I try my best with this picture (and overlay the pipes with dashed line and annotate a few spots).
(1) shows the hot water copper pipe coming from the water heater (actually the mixer valve behind the tank). From there, a bend happens and the pipe goes just a few inches over the water heater filter (5). There is also a tee that goes to the 2nd floor bathroom (4). Then two more bends and another tee. To the left (2) is the lower bathroom and to the right (3) kitchen.
I would like to reconfigure this mess such to remove all of this stuff and run the line from (1) directly into a tee of the line (2)-(3). Also, change (4) such that it tee's directly into that line.
- I have done lots of electric and general stuff but not really plumbing (except repairing valves). Is this DIY-able?
- What is the recommended approach here? On one hand, I'd love to do soldering but it is already extremely tight and there's also a gas line right next to it. On the other hand, shark bites look to be easier and since it's open (and not buried behind a wall) maybe not an issue? Water heater probably be replaces anyway in 15 years
- Is there any reason whatsoever for the plumber to create this mess? Is there any reason not to tee directly into the vertical (2)-(3) line?
- Anything else that I should consider?
One concern is that I need to get this done within a day or so, otherwise we won't have hot water.
