This is semi-related to another question I posted but more of a fundamental/elementary question about plumbing in general.
When one has a tight space, how does one make a run of pipe slope when only 45, 60, and 90 degree fittings are available?
For instance, I have this transition from a 3x3" Combo Tee-Wye that needs to run to a toilet flange. I have about 8 inches between joists to make this fit, so running perpendicular 90s under the toilet flange won't work.
Below I'm showing my goal (orange pipe sloped at 2 deg) and all the blue piping is plumb or otherwise following an X or Y axis. If I were to try and mate the orange and blue, they'd bind and not mate.
Also, I plan on using a 45 deg angle flange, but didn't have a 3D model for that. Either way, we're trying to transition from 90 degrees to roughly 88 in order to make sure that poop is flowing where it needs to.
