We have a deck that needs to be repainted and some areas have chipped paint that needs to be sanded. The house was built in 1993 (US), and I wonder if asbestos is a concern. I have not seen people worry about asbestos in deck paint, but I heard that talc is often used as a filler and asbestos often coexists with talc, so I wonder if this is a concern.
A 1993 home with an outdoor deck and you're going to wear a dust mask, right?
No concern at all.
You want to be careful with asbestos, but there's no need to be paranoid. Asbestos is a problem as a persistent dust in an enclosed area with long-term exposure. Short exposure is not a major risk.
While asbestos was occasionally used in paint, compared to things like insulation it was rare. Asbestos was banned in pretty much all products in 1978. Asbestos in paint in 1993 would have been specialty paints and unlikely to be in deck paints where its fire retardant properties would be irrelevant.
Frankly, I'd be wearing a mask, not because of the possible threat of asbestos, but because breathing in anything not pure and undefiled atmosphere is generally bad. And to make a point, if your area's like mine and currently covered in forest fire smoke, the smoke from those fires is a greater risk to you than the infintesimally small risk of asbestos in a 1993-era deck paint.
If you're absolutely terrified of asbestos, vacuum the remains using a high-grade dust bag. If you use something like Shop-Vac brand vacs, it's the yellow bags. Otherwise, wear mask, sand deck, bask in job well done... and don't worry about asbestos.
- 675
- 6
- 20
So the final answer is "send a sample and get it tested" as that is the only way to be sure.
You will get lots of "asbestos is not likely" or " never seen it happen on decks" but testing is the only guaranteed solution.
- 30,038
- 2
- 34
- 69
Yes, asbestos crystals may found in talc beds. Some quarrying operations were shut down when that was accepted as a hazard. However, the percentage of asbestos in the paint should be low (if any) and your exposure to it lower.
If you're really worried, I would suggest approaching this the way you would if the deck had lead paint: scrape rather than sand, so the paint comes off in larger pieces rather than breathable dust, and put down tarps to catch the scrapings so they can be disposed of rather than being left in the soil.
- 33,603
- 5
- 56
- 110
