I have a lighting circuit with several slim LED pot-lights that are controlled with a dimmer switch. I added a second switch (see diagram below) so that I can independently turn one of the lights off while the others in the room remain on.
Hopefully my diagram makes sense, I'd like to change things so that two lights are now turned off by that same switch.
EDIT:
Thanks for you answers! How does the following updated diagram look?
I'm trying to retain the existing wiring as much as possible in case I ever need to remove the second switch and revert my changes, hence the seemingly unnecessary junction boxes :)
