I have a Force brand boiler in the basement connected to a multi-zone baseboard system. I hear gurgling sounds in a number of the zones, and one zone doesn't reliabily heat (as of a few days ago). So I have decided to bleed the air from my system. Unfortunately, my system doesn't look like a lot of the ones I've seen youtube how-to videos. In particular, I don't see drain hose connection on the return-side of my boiler.
On the output side, I see the hot water pipe come out of the boiler and the go to the wall where it splits in to 7 zones, each with a automatic switch (connected to the room thermostat), a shut-off valve below the automatic switch and a hose-connection in between these two.
On the boiler itself, I see the return pipe (black), but there is no hose connection on it.
The return pipe is black and goes straight up to the ceiling.
In the ceiling, it seems to connect to the various zone return pipes.
But the root of my problem is that I don't see a hose connection on the return side, so I don't know how to drain the air/water from it. Does this kind of system bleed out a different way? The boiler's part number is Force 08N-RHG1
For additional information, here are some photos of other parts of the system:
I believe this is the feeder valve where fresh water can be pushed in to the system. It connects to the output pipe in between the boiler and where the various zones split off to the automatic zone switches.
Contraption on the boiler where the new hot water leaves to go to the zone splitters.
Contraption on the bottom of the boiler where the old water returns.
