looking for some clarity on sub-panel/EMT grounding. Been doing some research but not fully clear on some things.
Going to feed a sub-panel/loadcenter from a 60A breaker installed in a 200A main panel (no main breaker in sub-panel), using ACWU 4/3 AL cable. Two hots with 1 ground and 1 neutral separated at sub-panel (each into their own bar; neutral bar not bonded to sub-panel). No additional ground rod needed at sub-panel because located in same structure.
From the sub-panel, I will be running T90 in wall/surface mounted EMT to all planned electrical boxes. I understand that EMT is an acceptable ground run but not sure if grounding bushings are needed at the sub-panel?
Going into the sub-panel (for the ACWU 4/3 AL), I will be using an aluminum 3/4" 1-screw clamp fitting using full knockout.
Coming out of the sub-panel (to the electrical boxes) will be 1" EMT with steel or zinc alloy compression connector using concentric knockout.
Do I need a grounding bushing at the 'in', 'out' or both points of the sub-panel. If so, I can only find aluminum grounding bushings. I assume that would be fine for the 3/4" aluminum clamp fitting but is it ok to use the aluminum grounding bushing with the steel or zinc alloy connector on the way out of the sub-panel? Again, this is if the bushings are needed at all?
Also, I've read that any concentric/eccentric knockout used at the sub-panel and along the EMT run to the electrical boxes would also need grounding bushings. Or the alternative is to remove the entire concentric/eccentric knockout and use two reducing washers. This, supposedly, is good enough to keep the ground going through the EMT (reducing washers not applicable at sub-panel for grounding purposes, I believe; only at electrical boxes?).
Sorry for the length of my question but trying to be as detailed as possible.
