While doing yard work, I cut a dime-sized hole in an underground schedule-40 PVC pipe (irrigation supply, pressurized when it's on) just where it enters a 90° elbow. I can see how to fix this, but it looks like it's going to require a new 90° elbow and two coupling sleeves, for a total of six welded PVC joints.
Am I missing a simpler configuration? I've considered flexible hoses, but I think they might not do well underground—specifically, it seems likely that they would get crushed.
If I'm doing this six-welds nightmare, is it better to do all six welds at once, to reduce the risk of breaking an existing joint, or to do a few of them first, let them fully cure, and then finish the job? The natural ordering here (after dry-fitting the whole thing, of course) would appear to me to be to weld the two new short straight pieces into the elbow, let that cure, then do both of the welds on one of the straight couplings (presumably the longer one, to distribute the flex required by the last weld), then the welds on the other, shorter straight coupling.
