I've seen questions similar to mine being asked before but every solution appears to be a "hack" that is likely to fail shortly after installation. I'm hoping that someone knows of an "industry approved" solution that has eluded me so far.
The goal is to have a ventless natural gas fireplace with millivolt ignition as emergency heat and as a source of humidity, and continue to use my current 24VAC HVAC furnace as primary heating. I doubt it changes anything about the solutions that I intend to humidify my house with a ventless fireplace but I thought I should mention it out of completeness.
Like many of the solutions I've seen with a similar intent I'd want a "dumb" thermostat in parallel with the primary "smart" thermostat so that if there's a power outage while I'm away or asleep that the house doesn't turn into an icebox. The question is then how to attach a millivolt fireplace to a 24VAC thermostat.
The most common solution I've seen is to get a common and inexpensive fan control relay to close the millivolt circuit on the fireplace. While this certainly works for some definition of "work" I'm concerned about running DC through relay contacts rated only for AC. I've seen this done before and the usual outcome is the contacts get burned out fairly quickly from the DC arcing.
Another popular solution that concerns me is seeing people use 24VAC dry contacts in a thermostat to control the millivolt ignition circuit on a fireplace. There's a reason that not all thermostats are rated for millivot DC, DC can burn out AC switch contacts or overheat a solid state circuit.
I have two smart thermostats already, one that provides a 24VAC output for humidity control, and the other has 24VAC rated dry contacts. I should be able to use one or the other for this project, in addition to a millivolt "dumb" thermostat to fall back on in case of an extended power outage.
Should I expect a fan control relay to work fine to operate a millivolt fireplace? Are there relays built for my intended application that I simply have not found yet? If so is there a specific nomenclature for these devices I should be using to find them more easily? I'm not seeking product recommendations but rather what I can expect these relays to be called so I can search for them at a hardware store.
I'm quite certain that the dry contacts on the one thermostat I have will not react kindly to a millivolt fireplace. I'll have a long run from the fireplace to the thermostat and that will call for 14AWG wires to minimize voltage drop, and the contacts on the thermostat don't appear large enough to accommodate that size of wire. I've been trying to find out how much current flows from a typical thermopile but haven't seen a useful number, but if they want 14 or 16 AWG wire then it must be significantly higher than that seen on 24 VAC systems where 18 or 20 AWG is the norm.
In trying to work the problem backwards I thought I'd see how much power a gas valve takes since that should tell me how to size up the relay.
I found this as something I believe to be representative of a common fireplace gas valve: https://images.thdstatic.com/catalog/pdfImages/25/2582b4e1-4efa-4fcc-a7c7-7001b6dba1c1.pdf
This table is from that spec sheet but I added the power column.
| ELECTRICAL RATINGS | Power | |
| 24 Volt Models | 12 VDC - 0.18 amps | 2.16 W |
| 24 VDC - 0.2 amps | 4.8 W | |
| Millivolt Models | 250 MV to 750 MV | ??? |
| Line Voltage Models | 120 VAC - .034 amps | 4.08 W |
| 240 VAC - .017 amps | 4.08 W |
If I assume the voltage drop to the valve results in 250 mV at the valve and it's consuming about 4 watts then that's 16 amps. If I assume about 750 mV at the valve and it consumes 2 watts then that's about 2.5 amps. Given that I've seen people claim they've been using fan control relays rated for 240VAC 6 amps and not have them immediately melt down then it seems the numbers are at least close.
I can keep doing the math but what I'm really searching for is a spec sheet on a few thermopiles that list the current they produce in addition to the voltage. It seems odd to me that such a fundamental detail isn't shown on spec sheets so that installers can select the proper size wire and such for an install.
