Can someone explain why the following older switch is labelled a three-way switch and how it would have been used as such?
It recently stopped working so I want to replace it. Based on the appearance of the switch, age of house, and age of wiring entering the switch box, my guess is it's a minimum of 40 years old, maybe 60+. It was in use as a shut off for a furnace so I expected it to be a basic single pole switch.
However, as you can see in the second picture, it's labelled "THREE WAY 5A-250V-10A-125V" on one side of the switch's front metal plate, and "SINGLE POLE 5A-250V-10A-125V" on the other. The toggle itself has ON and OFF labels, contrary to most modern three-way switches. There are only two terminal screws. One screw is kind of brassy. The other looks a bit coppery, but that might just be tarnish.
So I'm confused about whether this is three-way or single pole. All the three-way switches I see for sale now have three screws: one common and two travelers, and do not have ON/OFF labels on the toggle.
Could it be that that as a cost-saving measure, Leviton manufactured one metal plate that they used for both three-way and single-pole, and the location of the screws indicate which label applies? I.e. in my case, the screws are on the single-pole labeled side of the switch, so this is a single pole switch, and on the three-way model of this vintage, all the screws (or maybe just both traveler screws) would be on the three-way labeled side.
Can a switch be both single-pole and three-way? If so, how would one use this as a three-way switch?
Thanks.
