There is an outlet CRB5362 with side wire and back wire capability with screw-pressure-plate back wiring.
The instruction says: "Tri-drive steel terminal screws. Internal screw-pressure-plate back and side wire capability. Two back wire holes for more wiring flexibility. Convenient back & side wire installation". The sign between "back" and "side" is "&" which mean I guess "and".
In the picture, the black wire is in the side wire location and the red and white wires are in back wire holes. There are three wire colors in the picture for easier discussion. The question is not about the colors but about configuration. I just took the wire pieces what I had. Do not worry about white wire going to hot screw. The outlet in the picture is not really connected to power. You can assume all wires are black.
Do not worry about ground in this question.
Is it OK? There is one more hot screw with side and two back wires. I do not have the option, but is it OK to connect a total of 6 wires to one outlet?
