The mosaic is 1/4" thick, the porcelain planks are 3/8" thick. What's the best way to install?
I'm thinking I need to build up the floor where the mosaic will sit. I could use uncoupling membrane -- put 1/4" plywood on subfloor where mosaic will sit then cut membrane to fit the 2 different thicknesses. Or use backerboard, and build up where the mosaic will sit with something on top of that, but what -- more cement board? Uncoupling membrane? Some kind of underlayment?
