What is the best way to twist conductors together before applying the wire nut?
That probably sounds like a silly question. But when I try, most of the time I end up wrapping one conductor around the other instead of truly wrapping around each other. And that leads to an insecure connection since the mostly straight conductor can just pull out of the coil of the conductor wrapped around it.
My usual approach is to hold the conductors parallel to each other, gripping them with my left hand about 1/2 to 1 inch below the end of the insulation. Then to twist with lineman's pliers with my right hand. I've tried applying the lineman's pliers just to the tips of the stripped part of the conductors, about half-way down the length of the stripped conductors, or the entire length of the stripped conductors. I've also tried holding the conductors at a very slight angle (maybe 5 to 10 degrees to each other), crossing at the point where the insulation ends, so the stripped ends form a "V." But that hasn't worked any better.
Is there a trick to getting the conductors to truly entwine?
