I have an outdoor GFCI that feeds several downstream outlets that are also outdoors. Recently it has rained pretty heavily and now the GFCI is tripping after about 10+ minutes, not sure if the exact timeframe because it seems to be pretty variable. I'm sure moisture is getting into one of the downstream outlets causing the trip, pretty sure it's not getting the GFCI itself though cause it's well covered. I was wondering if there was a good way to troubleshoot which outlet is the one being affected and causing the trip. Yo complicate things it's a warm day today and things are likely drying out which makes it hard to troubleshoot for the next time it rains. Any help would be appreciated
Edit: yes the downstream outlets and the GFCI have an in-use cover on them.
Orionox
First off, GFCIs can and do go bad and ones installed outdoors need to be the weatherproof ones so that could be your problem. As far as troubleshooting goes, all you can really do is start disconnecting outlets, one at a time, and wait to see if the GFCI trips. If it doesn't, connect the outlet back up and disconnect the next one inline and so on. If it's a really inconvience when the GFCI trips and you loose all the outlets, think about replacing the regular outlets with GFCI outlets and eliminate using the load terminals on the first, existing, GFCI.
JACK
  • 89,902
  • 214
