The Problem
I need some help installing Ikea high cabinets. The photo shows 1 out of 2 cabinet constructed. The instruction states that I should:
- Install a metal beam on the wall
- Install 6 flimsy plastic legs on the bottom
- Hang the cabinet on the wall, then adjust the flimsy plastic legs.
However, the pantry looks dauntingly heavy.
Chat GPT gives an estimate of:
- for the cabinets alone: 400 lbs (180kg)
- Light pantry use: 1520 lbs (690kg)
- Heavy pantry use: 2645 lbs (1200kg)
Ikea says each leg holds 275lbs (125kg).
Question 1 - How should I mount the rail?
Ikea's instructions say the rail should be screwed into studs every 12" (30cm). Unfortunately, my studs don't line up like that, as seen from the pictures.
a. Oversize the rail so that the left side sticks out (ugly). That way I get a 3rd stud to screw into. Use #8 GRK cabinet screws. Do 1 screw in the rail's mounting hole, and an additional screw underneath the rail for additional support. Do this 2x on the thicker support column. This gives 8 screws to support the cabinet, but support will be weak on the right side. Additionally, screw the cabinet to the existing small cabinet on the right for a little bit of support.
b. Do not oversize the rail. Instead use drywall toggles on the ends for a little bit of support. As before, use GRK screws, double screws per mounting hole, and double mount on support column. This gives 6 screws and 2 toggles to support the cabinet.
Question 2 - How should I support the bottom?
I worry about damage to the hardwood floor, putting too much weight on the studs and damaging them, and not lining up the support properly, so that all the weight is on the wall or all the weight are on the legs.
a. Follow Ikea's instructions and use 6 flimsy plastic legs.
b. Create a toe box using 2x6, trimmed to 4.5". Hope it doesn't warp. I have never done this before.
c. Create toe box using plywood. This transmit the weight to the ground on a 0.5" plywood, which isn't much surface area. Slightly higher difficulty. Also never done before.
d. Buy additional metal legs from Ikea. Drill additional holes and put them in. Keep using the existing plastic ones for they support mounting a toe kick board, but add 3 metal legs on each edge for additional support. This totals: 4 plastic legs, 11 metal legs. The advantage of this is adjustability so that I can be sure the loads are being transmitted to the legs + wall at the same time.
References:
cabinet 1: https://www.ikea.com/ca/en/p/sektion-high-cabinet-frame-white-40487419/
cabinet 2: https://www.ikea.com/ca/en/p/sektion-high-cabinet-frame-white-10265448/
rail: https://www.ikea.com/ca/en/p/sektion-suspension-rail-galvanized-60261527/
plastic legs: https://www.ikea.com/ca/en/p/sektion-leg-90556071/
toe kick that mounts to plastic legs: https://www.ikea.com/ca/en/p/foerbaettra-toe-kick-matt-white-90417754/
metal legs: https://www.ikea.com/ca/en/p/capita-leg-stainless-steel-60263574/
GRK cabinet screws: https://www.homedepot.ca/product/grk--8-x-2-1-2-inch-star-drive-round-washer-head-low-profile-cabinet-screws-climatek-coated-100pcs/1000739692
