I'm getting ready to install drywall in my garage. In the process, I'm removing various nails and screws that the previous owners had used for hanging and storage. Basically I'm removing anything that is protruding from the framing. Running across the middle of the my garage ceiling there was a 2x4 that was screwed into the bottom chords of the roof trusses. It didn't seem like it was doing much: there was a noticeable gap between it and a couple of the trusses. Additionally it was only supported on one end by a short 1x1 and on the other a short 2x4, each of which were screwed to the sides of the top plates with only a couple screws. Its installation seemed like a hasty afterthought and it seemed to have no structural purpose whatsoever. I figured it was just put up there for hanging stuff and item storage even though it didn't notice any hanging hardware installed in it.
Upon removing it, however, I was concerned to see that it ran directly underneath where the two bottom chords that made up each truss were spliced together. My trusses have this type of design (credit Construction Concept Design Build LLC):
My bottom chords are spliced together in the middle, directly under the king post. The 2x4 I removed ran directly below the splices. Was that 2x4 there to provide some kind of structural support? Should I keep it in place and butt my drywall up to it? My garage is 24 ft long, so each bottom chord is made up of 2 12ft 2x4's. Perhaps that 2x4 I removed was there to provide additional support for the trusses which otherwise don't have any support along that full 24ft length.
Here's a picture of one side of my garage where I removed the 2x4. You can see where it was below the splices as indicated by the indentation in the insulation kraft paper.
Depiction of where the 2x4 was located:
Images from attic space. The first picture shows a plywood strip fastened to the trusses, spanning three of them. In the second, a door can be seen which is being stored up there. I moved it aside to get a good look at the middle of the trusses, above where the 2x4 was.
