I've recently begun designing and building structural updates to my house. For example, I've built some shelving units and a cabinet space. Everything has gone well so far, but I'm about to tackle something more significant, a self-designed backyard shed, and I want to be sure that it is structurally sound.
The design will have non-traditional elements, such that copying an existing design would not be straight-forward and could not be relied on.
Is there a software tool or online resource that can help an average DIY'er calculate the load capacity for different structures using different materials? For example, if I use a 2 by 4 here it will be able to hold X weight, versus using a 1 by 3 can hold Y weight.
Or maybe there's are rules like 2 x 4 braced every 2 feet can hold 200 pounds. If this is the case is there a book or website that can provide me with guidance like this?
Bob.
  • 93
Safe loads are determined through engineering and experimentation. The experimentation is used to gather real-world data, which then is used as input to engineering processes, which then result in guidelines and building codes.
This is all updated over time as new materials are introduced and new experience is gained.
When there's a situation that is non-standard, there are two common approaches to dealing with the situation. The first is to pay an engineer to provide guidance on an appropriate approach. The second is to simply overbuild. An experienced builder will know when it's okay to overbuild, and when you need an engineer.
To get back to your original question, it has no simple answers. It involves the materials used, how they are assembled, and what sort of forces they are going to be asked to deal with. If you can post more detail on your design, I can advise you on any deficiencies that I see, but I'm not a professional.
Eric Gunnerson
  • 2,977
