I am installing a rooftop antenna on the end of my house, opposite the end where the ground rod is located.
I plan to install a new 8' ground rod on the ground directly under the antenna. I need to connect (bond) the new ground rod to the old ground rod. I plan to do this with 6 AWG copper wire. Because of a variety of obstacles, running the 6 AWG around my house to the existing ground rod would be difficult.
Would it be safe to run the 6 AWG bonding jumper in PVC conduit through my semi-finished basement? For example, attached to an unfinished concrete wall?
Edit: I've ended up running the 6 AWG in the ground around my house. I could not find any good information about running it inside versus outside, so Iopted for the safe route, to keep it outside.
RobVM
  • 73
I've cleaned up after lightning hits an antenna, and designed spark gaps to protect electronics. The last thing I'd do is install a lightning rod through my basement. That stuff should stay outside, irrespective of NEC 810.21(J). Ground loops are not a serious concern in this particular application.
I'd also consider changing the 8' rod into two 4' rods, which are far easier and safer to drive into the ground.
Bryce
  • 11,057
  • 77
  • 120
Yes,
PVC or EMT conduit can be used to route the wire. If you're just passing it through a basement, insulated wire can be passed directly with the conduit being utilized where the wire is not protected by the home.
user15912
