I currently live in a rented apartment and the windows in my shower are not sealed, so it gets pretty cold there. The front door of the house also has a sealing problem.
The thing is, I'm not going to stay in this apartment more than a couple of months.
So, what are some good, cheap, fast solutions to seal my windows and front door as much as possible?
samthebrand
  • 235
  • 40
Asaf
  • 283
If your leaking problem is from loose fitting window sashes or a poor fitting door, the simplest and cheapest method would be to purchase some self-adhesive foam weather stripping. This rolled product can be easily installed at the bottom of a window or around the outside edge of the door frame. Select the smallest size that will help seal the gaps, then just peel and stick. Too large and you may have difficulty closing the door etc.
Another good window treatment is the clear plastic window film like the 3M Indoor Window Insulator that mounts to the frame of the window. Use a hair dryer to "stretch" the film, thus sealing any air leaking in around the sides or through poorly glazed panes.
All these products are cheap and available at any hardware store or box store like Lowe's or Home Depot. Stay warm!
  • 20,909
  • 95
  • 135
shirlock homes
  • 58,628
  • 87
  • 168
There is a removable clear caulk you can buy from most home improvement stores that you can use to seal that window and peel the stuff off. I bought some from Menards at $2.50 each on sale. Caulking guns can be bought for a couple of bucks.
Frank
Get a window insulator kit. It is made of a clear, plastic material that goes over the window, with double-sided tape around the edges to seal it. It's easy to set up and helps a lot with drafty windows.
  • 20,909
  • 95
  • 135
Joe Phillips
  • 2,286
  • 46
  • 61
If you can actually see the gaps in the windows, a can of "Great Stuff" would probably do the trick. It's an expanding foam that you spray into gaps.
Or you could use a squeeze tube of "DAP Silicon II" and run a bead of it around the window. I'm going to assume that if you're in an apartment for the short term you either don't have a caulking gun or don't want to buy one (don't need yet ANOTHER thing to move when you do move), so the link goes to a "squeeze it yourself" tube of Silicon II.
As for the door, if it's just a short term thing you may want to just wad up a bath towel and put it along the bottom of the door as a draft blocker for the short term.
