Like the questioner in Do I need to do anything to protect my pool during a rare freeze? I live in central florida and its going to be a hard freeze tonight. Do I need to let the spigots drip or cover them for a short period of time? It is much less water volume than a pool, but there is also much less exposure since it goes right into a cinder block wall.
chotchki
  • 460
A short freeze should not be a big deal for your area. I just bought some of the spigot covers for mine. I live in Virginia and have a bit colder temps than you do. Normally we have no problems with our area either. I just covered them to make sure.
Doresoom
  • 15,873
  • 83
  • 122
Doc Walker
  • 910
In colder climates at least, the norm is to have either shutoffs, or frost-proof sillcocks.
A shutoff is simply a valve on the inside of the house. You close it off, then open the outside tap, and the water drains out of the pipe in the wall.
A frost-proof sillcock (pictured below) is a tap with a very long stem, so the shutoff is actually at the base inside the house. The part that is exposed outside and in the wall is empty when the vale is shut.
alt text
If you have one of these, you are fine. If you have shut-offs inside, I would close them and open the outside taps.
gregmac
  • 29,300
  • 89
  • 162
For rare freezes, you can turn on the faucet slightly, to drip a little. This will keep fresh warmer water coming in, and reduce the chance of freezing.
If your house has a crawlspace with the plumbing, those pipes are potentially susceptible to freezing, too. This trick helps there, as well.
Obviously, this is a waste of water if you have to do it more often.
Jay Bazuzi
  • 11,778
  • 100
  • 143
