I have a sliding screen door that leads out to a porch/deck. The door continually sticks and is just doesn't slide open cleanly. Otherwise the screen and everything is fine. Is there something I can do to fix this or do I need to replace the entire screen door?
brendan
  • 1,155
Have you tried lubricating it? Seems worth a shot for the price before replacing the whole door.
Doresoom
  • 15,873
  • 83
  • 122
My Dad used to use Ivory soap! It worked very well but with any thick lubricant it needed to be wiped off and replaced now and then because it would collect dirt. Use as little as possible to get the screen running smoothly along the track by moving the screen back & forth.
KathyAJT
You can use a silicone spray lubricant. One I've used is called Blaster though there are other brands. You want to use a lubricant that does not leave a film. Just ask the clerk and they will know what you are looking for. WD40 would be the worst thing to use for this on many levels. You don't want to leave a film once you spray the surface because it will be messy and attract dirt and grime. This stuff will do the trick and has multiple uses around the house such as windows to help them slide easier and your garage door hinges.
  • 20,909
  • 95
  • 135
-1
Take your screen to a glass company. They usually have or can get replacement rollers.
  • 20,909
  • 95
  • 135
Brian
