Here is the front of my house. As you can see it is a 2-story dwelling on the left with a garage on the right that is connected to the main house by a "sunroom" (porch/breezeway/whatever). The main house has a basement, but there is nothing underneath the sunroom or garage.
Here is that sunroom from the back (excuse the mess - still finishing off Fall cleaning):
Where our concrete patio meets the foundation under the sunroom we have a big hole that has opened up (about the size of a golf ball) that you can see in the center of the photo:
And up close:
We've lived in the house for 4 years and this is the first time this has happened. I believe water caused this hole (we live in upstate NY and the cold winters and ice have chipped away at it year after year). The concrete patio was never poured correctly so it slopes (slightly) towards the house, and in the Spring when the snow melts the water funnels towards the house.
Some questions:
  1. Why is there a big hole there? Shouldn't it all be solid concrete?!?
  2. If left unattended, what's the worst case scenario here (so I can justify spending money on a solution to my wife)?
  3. What is the best DIY way to fix patch this hole so we can get through another winter?
  4. What can I do in the long run so that this doesn't keep happening every year?
Thanks in advance!
bfodder
  • 581
This part of the foundation is most likely spreading out a roof load from a sizable portion of the sunroom roof. If the soil supporting the foundation has eroded away, this will need to be rectified some time next year.
For now, get a bag of ready mix mortar, the kind you just add water to, it has sand and cement already mixed in in the correct proportion. Mix up a small amount, keep the water to a minimum so it will stay where you put it and not slump down. Patch the hole. That's all this is right now, a temporary patch.
If the hole opens up beyond such that you feel like it's sort of a bottomless pit, cut a short length of something like a paint stick. Thin enough to push through the hole but long enough to wedge inside when turned 90 degrees. Tie a length of wire to the center so you can keep it pulled tight when you push mortar up against it.
As you suspect, water and freeze/thaw cycles chip away at the foundation over time. There was probably once a innocuous hairline crack there at one point. Water got in there and froze, opening the crack. Repeat dozens of times a winter and over the years you get what you see now.
The solution is keep water away from the foundation. I see you have a gutter system over this area. That is good. The patio sloping towards the house is really bad. Not only does it get into foundation cracks and erode the material, water gets under the house structure and can cause uneven settlement, stressing members in ways that was never intended. Some people think crooked floors in old houses are "charming". In reality it is a sign of an unstable structure. Even if the house stays stable, water can be the source of toxic mold. Water has no place in your house other than inside plumbing.
You need to correct the drainage issue. Ideally, it should slope by gravity away from the house at least with a 2% slope. Another solution, not nearly as good, is to place a sump at the lowest point and pump collected water away. I can't emphasize enough how a natural gravity solution is far superior to a mechanical solution. Sometimes you do what you have to do though.
Combine this with the possibility of needing to correct erosion under the foundation. You my be digging up the patio anyway. OTOH, if the foundation is still properly supported and you correct the drainage issue, your little mortar patch could possibly be considered a permanent fix.
bcworkz
  • 11,578
For question number 1, no, its not supposed to be solid concrete, it could, but in this case you have hollow core block, the solid concrete is above this block that makes the floor. The vertical lines I see in the picture are the head joints of the block and they should be about 16 inches apart.
The freeze/thaw cycles affected this particular block where the surface is eroded away to expose the open cell of that part of the block. Some block are affected differently than others, this one happened to be the weakest in this run of block work, and the patio sloped the wrong way expedited the erosion.
Question number 2, the worst case scenario is foundation settling and mold as mentioned by bcworkz. Both issues though depends on existing factors, soil type, for the foundation concerns, and how well the soil was compacted when the house was built, for the settling of the interior slab. And what type of organics are present in the soil to feed the presence of mold. It usually has to have something to feed on to grow, and it may only need the dirt to do this, although I have only seen it grow on drywall, wood or wood chips and other construction materials.
Question 3, to fix it in the short run, bcworkx has a good method with the wire and backer, that would be good for the winter. The open core of the block is much larger than the hole you see.
Instead of a temporary fix, it should be the first step of the permanent fix. Repair the hole by chipping away at the hole to expose the whole core of that block, at least in it's width. That will serve two purposes, it will let you see how strong the block is as you chip away at the opening (if it is weak, it will turn to sand as you chip away at it) I am presuming this is concrete block not slag block or cinder block, the textures in the picture don't suggest that it is, yet I don't see any aggregate for it being concrete block either. Either way the chipping away will ensure a sound surface for the new masonry cement to bond to. The second purpose is the larger hole will allow masonry rubble or even gravel of one sort or another to go into the web of the block to give a base to support the repair cement to fill the hole. Only issue you may have is there is a long crack that may allow multiple cores to be exposed, no problem, more of the same remedy, read on. As you fill the hole, have other masonry rubble (positively no organic material!) to shove in the hole as you place the cement in the hole. that way the cement will not "slump out". If it insists on slumping out, it may be too wet, let it set for a while to a semi hard set and scrape off the slumped out part flat enough to be even with the rest of the block, the fill the rest after it has set a day. Cement should be peanut butter consistency, for example. Toothpaste consistency is too wet. With care and proper prep, it can be done in one shot, the trick is having enough brick or block rubble to shove in the hole in layers as you fill the hole with cement, like laying really small bricks.
Question 4 builds from the steps in number 3. Minimally you need to remove the patio slab that is against that wall, say a foot or so, to parge the surface of all the block on that wall with type S masonry to give that part of the wall a new weather surface, and to tie that parging in with the waterproofing layer below grade. Then, if there is a asphalt based waterproofing on the original foundation, it give you a solid surface to apply more foundation coat to. I don't think there is any existing foundation coating though, it is a slab on grade as it is called, and there was no need to protect the living space above grade. It is done nowadays to prevent water migration through the walls and getting to living space walls underground, preventing Murphy's Law from happening.
The second part of the permanent fix is to either break out all of the faulty pitched slab and pour a new slab pitched the right way with a minimum of a 4 inch step out of the door, max of 7 3/4 inch (building code maximum)and the 2% pitch minimum as Bcworks had mentioned previously. It can be pitched more and you can adjust the step at the door shorter or higher to do so. Use expansion joints at the house.
OR shorten that task by pouring a stoop over the existing slab, to the corner of the house, close to the edge of the siding as a height gauge, stay away about an inch or the siding will degrade quickly if the concrete touches it. Just make sure it is pitched away from the wall with the door minimally (2%). Also use expansion joints at the house.This fix is not recommended, for I would render a guess the existing slab beyond the corner is still pitched the wrong way too. This would still allow water to seep under the new slab at the joint of the new pour and freeze/thaw may have its way with that slab too, at least possibly, but I never liked dealing with possibilities. FWIW, the water that would still puddle there would freeze in the winter and cause a slip hazard, I imagine that is the case now...
Jack
  • 38,117
  • 66
