What will happen if I connect hot water to a dish water that is not designed to take in hot water?
Will it break? Or will I just not be able to use the cold programs?
Sandra Schlichting
  • 459
The Siemens SK26E220EU manual says:
Water temperature: cold water preferred; hot water max. temperature 60 °C.
Which appears to imply that it is fine so long as the hot water is no more than 60C at input. It includes a water softener, so it may well have some parts in the water path before it heats the water hotter that would be damaged by hotter water. If your hot water is electrically heated, it makes little difference to your overall operation cost - if you have an alternate, less expensive source of hot water, you'll benefit, so long as it's not too hot.
For other models, check the manual - or just hook it up to cold if you are electrically heating your water anyway.
Follow the manufacturer's instructions. New and higher priced dishwashers are more frequently starting to connect to cold water. The better dishwashers fill with so little water that the hot doesn't arrive anyway unless you let the sink water run like in the shower. Better energy efficient washers heat their own water to the proper temperature for better cleaning and sterilizing. When buying a dishwasher, one that heats its own water will use less energy than that household hot water supply and is a good feature. Using so little water it takes very little energy. Read the directions.
  • 20,909
  • 95
  • 135
Barry
  • 81
The Bosch SKS62E12EU offers an intensive wash at 70C or about 150F and a 'Maximum temperature for water intake 60°C'. So your answer is hooking to hot water is fine, and will save energy if your central heater is gas fired. Obviously, it can't chill the water, so you'll have only hot wash available.
Bryce
  • 11,057
  • 77
  • 120
