I recently purchased an inexpensive bath vanity from the Home Labyrinth. It included a low-end granite top that is not properly sized for my bathroom. Unexpectedly, out of the box, the granite is sealed to the wooden top of the unassembled vanity. I really like this vanity's wooden cabinets, but I need to replace the granite with a custom cut size and color.
Is there a good way to separate the granite from the wooden vanity without damaging the wood or the granite? The two pieces are very tightly fitted together. I can't seem to squeeze a utility knife between them. Is there a good strategy for separating granite away from a wooden cabinet? Is this something that a granite specialist could handle easily?
I'm starting to think that a sledge hammer might be the only way.
user685673
  • 141
You'll have to get it started somewhere, but a thin wire wrapped on a handle at each end (as for cutting cheese) will normally cut things off if glued with something reasonable (ie, silicone or similar.)
If they epoxied it in place, it's going to be much more difficult. Heat would be my first approach in that case, hoping the stuff softens, or turns out to be hot glue rather than epoxy.
If you don't care about the existing granite, a hammer strike near a corner should split the slab and make it easy to wiggle a large flat blade screwdriver to "separate and lift".
To minimize munging the cabinet, place a smallish piece of broken granite beside the next victim and use the former as a fulcrum.
wallyk
  • 12,399
