I store a bunch of the "outside stuff" in the shed for the winter. Mainly things that I only use when the weather is warmer. It pretty much remains locked up for the winter. Occasionally though, I have to run out there to get something in mid winter, and the lock is always frozen shut. I can get in by warming the lock up, heating the key, or using that spray deicer stuff. But is there any way to prevent this? Are there locks that would not allow this to happen?
The lock is one that is built into the handle, where the handle is vertical with the key in the center. When unlocked, it twists to a horizontal position. It is not a separate lock.
BMitch
  • 43,263
  • 98
  • 204
mohlsen
  • 6,359
  • 39
  • 47
5 Answers5
12
The problem here of course is that snow/freezing rain gets into the lock and freezes. With a house, this isn't normally a problem for a few reasons. First, you use it often enough that it doesn't get that bad, and second the inside of the house is warm, which prevents water from freezing inside the lock (unless it gets really, really cold I suppose).
You might want to look for a lock that has a metal shield over the area where you insert the key to prevent water from getting inside. Similar to what you have on a car door lock (and for the same reason). Personally, I've never seen any home locks like that, but that's not to say they don't exist.
A simpler option, and the one I would suggest, would be to put a plastic baggie over the doorknob and secure it with a rubberband. Then just take the baggie off when you need to unlock it and put it back on after you are done. It's a bit inconvenient, but if you hardly ever use the shed in the winter anyways, it should keep the water out and is probably the most practical option.
  • 20,909
  • 95
  • 135
Eric Petroelje
  • 9,729
  • 42
  • 62
you might be able to avoid this with graphite spray. By better lubricating the lock the water might not have time to collect and freeze in the tumblers.
boxed-dinners
  • 1,095
To keep water out of the door lock (knob type) in my gagrage, I split open a tennis ball ("x" cut) tied some twine to it, to attach it to the knob shaft, and put it over the knob. Works great.
user11756
Fill in between the handles with Vaseline to keep moisture from penetrating the lock. This method has worked for me.
  • 20,909
  • 95
  • 135
John
Fill up a cup with hot tap water and dunk the lock into it for a few seconds. That's how I've always managed to open it with ease :)
