I live in Northern CA.
  • For over 2 weeks, outside humidity is 90% (night) to 60% (4pm).
  • I use fans when cooking and bathing.
  • I keep the house temperature at 60-66 deg (night-day) and probably may drop to 57 when not at home during the day.
  • I try to open windows and ventilate, but that is hard since when I am home, I want to heat on and it tends to be night time so outside humidity is higher anyway
  • I have no basement
  • house is old, so I don't think it is "too air tight"
  • windows (about half) are old, single pan (not drafty though) and they get TONS of condensation every morning
Why is it that other houses I went to seem dry and maintain humidity at 40-50% while I have such a big problem lowering it?
Am I doing something wrong, like, should I heat the house to a higher temperature, will that help? Is getting a dehumidifier a (only) solution?
Aarthi
  • 1,143
csmba
  • 1,061
If you have a crawlspace with an earth bottom, it's possible the humidity is coming up through that--check whether you have a vapor barrier below your house. You probably don't, given the age of the house.
Getting a dehumidifier is definitely a possibility. Or a 'swamp cooler' arrangement, where cold water is used to make condensate that you then pipe out of the house, but that really only works in higher temperature air.
(edit) You may find some of this writeup really helpful.
Alex Feinman
  • 3,532
we have a similar problem with our house. so far we have found it has helped a little to get fully-vented soffit and roof ridge vents. this allows the outside air to move through your attic to vent the humid air.
condensation is a problem of insulation. the cold from outside is allowed to cool (either windows or poorly insulated sections of walls/roof) and the warm humid air inside condenses on the cool sections. if you have condensation on windows, you need new windows. if you have condensation on walls, you may need better insulation at those points.
dave thieben
  • 141
