14
I am trying to hang a mirror in the shower and it simply will not stay on the wall. It does not weigh more than a couple of pounds. There are two suction cups.
Things I've tried:
  • Cleaning the tile surface before attaching
  • Using water on the suction cups
  • Using soapy water on the suction cups
John Conde
  • 241
You could definitely just silicone the suction cups to the tile. This is kind of permanent in the sense that you will not be rearranging this, but not so permanent that you are hurting the tile. To take it out a putty knife would do the trick. Might have to use a solvent to get rid of the remnants but not a big job at all.
DMoore
  • 50,637
  • 93
  • 208
I had this problem recently with a shower caddy from IKEA. It lasted for about four months, then I bumped it, and I couldn't get it to stay. I cleaned the tile and the suction cups without success. The caddy fell in 15 minutes after putting it up. I found that my problem was how I cleaned the suction cups. After I washed them, I dried them with a cloth. This left tiny fibers on the suction cup which affected the suction. I then tried to let the cups air dry after cleaning them, and now they suck!
Try to clean your cups really well and let them air dry before using.
Edwin
  • 4,678
The best approach I have found is to make sure everything is clean and then apply a small layer of petroleum jelly to the suction cup. It helps to create an air tight seal.
treeNinja
  • 1,032
a layer of leftover soap scum on the tile or suction cups could be preventing the suction cups from sticking. Cleaning with vinegar or an appropriate cleaner might help.
Suction cups stick best when damp. However some suction cups are poorly made and will never stick well no matter what you do. You may just need to replace the suction cups with higher quality ones. the kinds that have a hinge stick best in my experience.
Jessica Brown
  • 596
