So I bought a Nest Thermostat off amazon, I read they used batteries and what not and after I purchased it I was looking at the description on amazon and it said it was a built in rechargeable battery (face palm) I have a 4 wire I don't have a common, I was wondering if it's safe or reasonable that,
I have a light switch basically a foot below the thermostat so I was going to install a 40va step down transformer to power the thermostat using the R as the hot from the transformer and the C as the neutral from the transformer, does this pose any issues? I googled it but people seem 50/50 some say it's great some say it's not a good fix and to pull a new wire, but pulling a new wire at this point in time is not an option. If I left the R straight from the furnace and just used the neutral from the transformer would that be worse than setup 1? (Using the hot and neutral from the transformer) as far as I know all the thermostat does is use that power to close and open contacts in the thermostat so it shouldn't matter if the tstat is powered off a transformer, should it?
Sorry for poor phrasing wrote on phone.
Datsik
  • 101
0 Answers0
