12
A few years go I sanded a stained table we had. Upon doing so, we discovered that it had really nice wood underneath. So instead of restaining, I applied about 4 coats of satin polyurethane. It looked nice.
Since that time, a few small spots have formed...typically from a wet spot when a coaster wasn't used. More recently, someone (cough kids! cough) managed to spill something on it and not tell anyone for about a day. As such, there's now a large spot down the middle where the liquid leached through the finish and raised the grain and flaked off the poly.
My initial thought is to get the sander out, sand the whole thing down again, and re-apply a poly finish. But is there anything else I should consider as an alternate DIY finish that can maybe stand up to daily use as a dining/homework/junk table in the center of our house full of kids? Or should I just live with the fact that it'd going to take a beating and that maybe I just need to re-apply a new coat of poly every now and again? If the latter, is there a benefit to add more coats that 4? Do I double the durability with 8, for example?
DA01
  • 24,586
  • 82
  • 153
For starters, I am going to guess you used a water based urethane instead of an oil based product? I have never seen a good oil based product react as you described to simple spills. I have seen some damage caused by very hot items being placed on a urethane finish, but normally, liquids will bead up and not penetrate the finish. Even though the water based urethanes are easier to work with, it take two to three coats to give the same protection as one coat of oil based urethane.
More directly to your question, the hardest finishes you could use as a DIYer would be a good oil urethane or lacquer. Lacquer finishes are common on high end manufactured pieces, but really need to be sprayed on, several coats to make a good protective finish. The end result of a lacquer finish is much like the finish on a car, very hard and durable. I have built many bars for folks and used 3 to 10 coats of oil based urethane with great results. I have never had a complaint similar to the problem you are experiencing. If I were going to fix your table, i'd probably start from scratch. Sand it down again, fix any color flaws then apply 4 to 6 thin coats of oil urethane, sanding with 220 or 440 between coats. I personally prefer using a 4 or 6 inch good quality foam brush instead of a bristle brush. Use thin coats, resist the temptation to put on too much at a time. Each coat applied and finished with long complete strokes across the entire table. Be sure to allow proper recoat time as prescribed by the manufacturer. Don't rush it! Not allowing proper dry time will create a "softer" finish as undercoats will not have gassed off enough and not hardened or cured.
shirlock homes
  • 58,628
  • 87
  • 168
