I'm filling a pool, and looking to speed up the process. I have two hose bibs, and wonder if I'm really gaining anything (and how much) by using both?
The house is supplied by a 3/4" line. This tees into two 1/2" lines, one going to each hose bib.
I'm thinking that with one hose, I'll get the volume provided by a 1/2" pipe. Adding the second hose will not double the flow, but should only make it as if a single hose was fed by a 3/4" pipe.
Is my intuition correct?
I would expect more water to flow unless you have extremely low water pressure. You have a 3/4" line and all the water pressure of either a municipal water system or a water pump. Splitting that into two lines will not likely double the flow rate as there is a pressure drop, but it should increase the total flow rate considerably. I would expect it to almost double, but not quite.
This would be easy to test with an empty bucket. Time how long it takes to fill the bucket with one hose on and then with both.
UnhandledExcepSean
  • 10,074
  • 39
  • 47
