The air in my attic gets superheated during summer, from the sun baking the (clay? terracotta?) roof tiles (I live in Sydney, Australia).
I have good ceiling insulation, and even put in some sarking (foil insulation just under the tiles) but some of the heat still penetrates into the house.
Also, we now have a ducted (central) AC unit in the attic which absorbs a bit of the heat and so cools a bit less effectively.
So I need to cool the attic (area about 100m2). I have 2 vents under the eaves (opposite sides of the house) and one small whirlybird (wind/convection powered thermal chimney).
Should I get more whirlybirds? They are about $100 each and I'm concerned they might not move enough air.
Has anyone used a solar or mains powered roof extracter fan? Can I get one for less than $300 or so?
How about heat-reflective roof paints, are they effective and cheap? (My roof is black and the house will lose a lot of resale value with a light colour)
Any other good solutions?
MGOwen
  • 683
Given that hot air raises, have you considered a Passive Stack Ventilation system. Basically:
  • A tall pipe coming out of the top of your loft so the hot air can raise
  • You must not have bends in the pipe or it does not work as well
  • The topping on the pipe must not add much to the flow resistance
  • The sizing of the pipe is important (sorry can’t help on this)
    • Too wide you don’t get fast enough upwards air movement.
    • Not wide enough, you get to much air resistance
  • The pipe must come out of the top of the loft and be high enough above the roof
  • Soffit venting of some type so the colder air can get in at the bottom
The system will only tent to pull air though the loft when the outside air is colder than the air in the loft (just what you need).
Given the correct conditions and design, a Passive Stack Ventilation system will work forever with no running cost or maintenance. Get anything wrong and it will not work at all.
Also check that your ceilings are well sealed, otherwise all the expensive cold air from your AC will just go up into the loft and be vented out.
ChrisF
  • 16,973
  • 74
Walker
  • 6,275
  • 66
  • 87
I'm not sure of the brand new cost, or relevant code requirements/restrictions, but my grandfather put a mains-powered attic fan on the side of my parents' house over the gable vent that sucks in cooler air to displace the hot air that builds up in the attic crawlspace. Combined with a few whirlybirds that acted as the exhaust, the crawlspace temperature dropped a significant amount (I don't remember exactly, but I recall it being on the order of 15˚F or so -- on a 110˚F, relatively windless day, the crawlspace was just extremely uncomfortable to work in, rather than absolutely inhospitable). They also noticed that their summer electric bills dropped by a fair margin due to needing less AC -- compounded by the fact that the AC ducts in the crawlspace now suddenly had a much lower temperature differential to their surrounding air.
Regarding the cost, my grandfather was a huge fan of flea markets, and I'd bet dollars to doughnuts that's where the fan came from. I'm not sure if my parents still have it installed, but it was still running reliably when I'd temporarily moved back home some 10 or so years after he installed it. Assuming he picked it up for US$50 or less (and knowing his thriftiness he wouldn't have paid more) that amortizes to $5/year or less (they saved about that much each summer month on their electric bill).
I can't say whether it'd be the best option for you, but, code permitting, it's certainly feasible.
Doktor J
  • 515
